Threads: 10
City: Columbia, SC
Greg, that's correct according to my radio, and my oscillator half way works, but it may be worth swapping lugs 1 and 2 just to make sure.
I can give you the connections for the RF coil if you still need them, the section is definitely working fine on my receiver. Have you tried injecting a 260khz signal to the grids of the 44 and 36 tubes? The instructions are on the schematic at NA. If that signal gets through, then I believe the oscillator circuits are tuned, and the problem is with the feedback.
I ordered 38awg wire to rewind, since Mr. Philco said it worked for him. Would like to completely rule out that coil. Out of curiosity, what material are you using to separate the two coils?
RE: Model 89 Cathedral - by skyscraper - 03-10-2014, 11:16 AM
Users browsing this thread: 38 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10588 online users. [Complete List] » 3 Member(s) | 10585 Guest(s)
