Tuning Eye Help
The value of R22? ... Good catch! .. I does not specify a value, neither does the parts list. I mistakenly looked at it and saw "22 Meg", which is wrong. It is R22. The one I replaced was 8M Ohm, so I will put that back in.
After replacing R22 with an 8M resistor, the voltage at R9 and R21 is 42mv dc.
Tuning Eye Help - by Jamie - 03-10-2014, 10:47 AM
RE: Tuning Eye Help - by Mondial - 03-10-2014, 10:59 AM
RE: Tuning Eye Help - by Jamie - 03-10-2014, 11:21 AM
RE: Tuning Eye Help - by Mondial - 03-10-2014, 11:34 AM
RE: Tuning Eye Help - by morzh - 03-10-2014, 11:41 AM
RE: Tuning Eye Help - by Jamie - 03-10-2014, 01:57 PM
RE: Tuning Eye Help - by morzh - 03-10-2014, 03:34 PM
RE: Tuning Eye Help - by Mondial - 03-10-2014, 04:29 PM
RE: Tuning Eye Help - by Jamie - 03-10-2014, 05:32 PM
RE: Tuning Eye Help - by morzh - 03-10-2014, 05:36 PM
RE: Tuning Eye Help - by Jamie - 03-11-2014, 06:54 PM
RE: Tuning Eye Help - by morzh - 03-11-2014, 07:29 PM
RE: Tuning Eye Help - by Jamie - 03-11-2014, 07:43 PM
RE: Tuning Eye Help - by Mondial - 03-11-2014, 08:09 PM
RE: Tuning Eye Help - by Jamie - 03-11-2014, 08:46 PM
RE: Tuning Eye Help - by BrendaAnnD - 03-11-2014, 09:46 PM
RE: Tuning Eye Help - by Jamie - 03-13-2014, 10:17 AM
RE: Tuning Eye Help - by Dan Walker - 04-01-2014, 08:55 PM
RE: Tuning Eye Help - by Conelrad - 04-02-2014, 02:10 AM
RE: Tuning Eye Help - by Jamie - 04-02-2014, 10:40 AM
RE: Tuning Eye Help - by Randy H. - 06-16-2014, 05:36 PM
