Philco 91H
To my embarrassment, I am having difficulties to move pictures from Photobucket.. Not that I dedicate most of my time to such venture, but tried few times with no success. Daughter"s involvement is in order.All the same, the cabinet looks unscratched and the innards are all intact and look proper as per multiple pictures I have found online.I think, the early ones had one band and the later ones had two, but I would not know until I get there.
Philco 91H - by fields 100 - 03-10-2014, 07:20 PM
RE: Philco 91H - by gregb - 03-10-2014, 07:43 PM
RE: Philco 91H - by fields 100 - 03-10-2014, 07:58 PM
RE: Philco 91H - by gregb - 03-10-2014, 08:21 PM
RE: Philco 91H - by Ron Ramirez - 03-10-2014, 08:37 PM
RE: Philco 91H - by fields 100 - 03-11-2014, 08:30 AM
RE: Philco 91H - by Ron Ramirez - 03-11-2014, 08:39 AM
RE: Philco 91H - by fields 100 - 03-11-2014, 08:59 AM
RE: Philco 91H - by Ron Ramirez - 03-11-2014, 09:03 AM
Philco 91 Tuning Condenser
There are currently 6994 online users. [Complete List]
» 2 Member(s) | 6992 Guest(s)
