Threads: 242
City: West Bend, Wisconsin
Thanks, Will. You were a lifesaver. And no your notes weren't confusing at all... what was confusing to me was why it was getting shortwave and not broadcast band! That's why I wanted to make absolutely certain I understood you correct.
I've been collecting and restoring radios for over 30 years now and never had a challenge like this before! But I was bound and determined to win the war and this radio is about ready to wave the white flag in my direction! LOL
Users browsing this thread: 44 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10484 online users. [Complete List] » 4 Member(s) | 10480 Guest(s)
