Gloritone 26P
You know it's possible. The few photos I can find of one of these shows knobs which are the same, or very similar...hard to tell in some of them. I'm hoping I can find something close to the original style grill cloth, that yellow stuff really bugs me. I could use it for my model 27 "outhouse" as well. Looked under the chassis yesterday. Whoever did the re-cap in the past did a pretty decent job.
Gloritone 26P - by Groundhog74 - 03-10-2014, 09:45 PM
RE: Gloritone 26P - by Radioroslyn - 03-10-2014, 10:24 PM
RE: Gloritone 26P - by Groundhog74 - 03-11-2014, 04:48 AM
RE: Gloritone 26P - by Jamie - 03-11-2014, 06:41 AM
RE: Gloritone 26P - by Eliot Ness - 03-11-2014, 02:08 PM
RE: Gloritone 26P - by Groundhog74 - 03-12-2014, 07:42 AM
RE: Gloritone 26P - by OldRestorer - 03-12-2014, 06:34 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7143 online users. [Complete List]
» 1 Member(s) | 7142 Guest(s)
