Philco 91H
@ Ron.I am getting the radio today. Like the idea of putting the chassis into the 91B cabinet very much, as I am not that fond of the floor models.I have a question. According to the pictures online, the 91B chassis carries that triple tube shield on the left, whereas the console chassis does not. How did you get around it to keep the look original? Besides,there might be an issue with an excessive heat from the tubes.
Philco 91H - by fields 100 - 03-10-2014, 07:20 PM
RE: Philco 91H - by gregb - 03-10-2014, 07:43 PM
RE: Philco 91H - by fields 100 - 03-10-2014, 07:58 PM
RE: Philco 91H - by gregb - 03-10-2014, 08:21 PM
RE: Philco 91H - by Ron Ramirez - 03-10-2014, 08:37 PM
RE: Philco 91H - by fields 100 - 03-11-2014, 08:30 AM
RE: Philco 91H - by Ron Ramirez - 03-11-2014, 08:39 AM
RE: Philco 91H - by fields 100 - 03-11-2014, 08:59 AM
RE: Philco 91H - by Ron Ramirez - 03-11-2014, 09:03 AM
Philco 91 Tuning Condenser
There are currently 10143 online users. [Complete List]
» 2 Member(s) | 10141 Guest(s)
