SW aerial
Hope I am posting in the right forum. What is the economical way to get adequate reception on SW? At this point I am just using 15ft of wire on the first floor of my place.Mediocre reception.Should I run the wire up to the roof, and if so, how far above the roof line? Should that insulated wire be shielded if the portion of it will be touching or laying inside the aluminum gutter? Thanks.
SW aerial - by fields 100 - 03-11-2014, 08:46 AM
RE: SW aerial - by morzh - 03-11-2014, 01:46 PM
RE: SW aerial - by Art Hoch - 03-11-2014, 10:04 PM
RE: SW aerial - by captainslack - 03-12-2014, 02:21 PM
RE: SW aerial - by Eric T - 03-12-2014, 08:55 PM
RE: SW aerial - by Radioroslyn - 03-13-2014, 08:18 AM
RE: SW aerial - by fields 100 - 03-13-2014, 09:01 AM
RE: SW aerial - by David - 03-13-2014, 01:42 PM
RE: SW aerial - by Radioroslyn - 03-13-2014, 05:28 PM
RE: SW aerial - by fields 100 - 03-13-2014, 06:29 PM
RE: SW aerial - by fields 100 - 09-03-2014, 09:39 AM
RE: SW aerial - by morzh - 09-03-2014, 09:48 AM
RE: SW aerial - by fields 100 - 09-03-2014, 11:42 AM
RE: SW aerial - by morzh - 09-03-2014, 11:56 AM
RE: SW aerial - by Mondial - 09-03-2014, 02:12 PM
RE: SW aerial - by David - 09-05-2014, 03:51 PM
RE: SW aerial - by David - 09-05-2014, 06:14 PM
RE: SW aerial - by fields 100 - 09-16-2014, 06:25 PM
RE: SW aerial - by David - 09-17-2014, 09:04 AM
RE: SW aerial - by PhilcoJohn - 09-17-2014, 07:44 PM
RE: SW aerial - by fields 100 - 09-17-2014, 10:01 PM
RE: SW aerial - by Mondial - 09-17-2014, 10:08 PM
RE: SW aerial - by David - 09-19-2014, 08:17 PM
