.5 10 cap and electrolytic box question
I have these caps that say .5 and 10.
Is that 10volts? is using 630v bad?
I have the Ecap box but it does not say a voltage either. sch. only says 8 and 8 uf. what voltage should I use?
http://www.nostalgiaair.org/PagesByModel...003114.pdf
.5 10 cap and electrolytic box question - by OldRestorer - 03-11-2014, 11:20 AM
There are currently 10172 online users. [Complete List]
» 1 Member(s) | 10171 Guest(s)
