Philco 91-221 antena transformer primary
Ah!
I think someone decided to use an outlet Hot as an antenna.
Lightening is also a possibility.
I dealt with this exact problem in the Emerson I restored this summer.
I was able to count my turns though when unwinding the coil.
It is bakes so badly you are not able to try to unwind it and count the turns? I you are off by a few turns it does not matter much.
In my case it was about 200 turns.
RE: Philco 91-221 antena transformer primary - by morzh - 03-11-2014, 04:33 PM
