Tuning Eye Help
Ok, update. I checked the tubes, and resistors, then did a full alignment. Success!! The tuning eye is now working. The alignment is what brought it to life. Thanks you guys!
Now, a question - I am not happy with the sensitivity of the tuning eye. I think this set was designed for use with a long wire antenna. It gets fine reception, actually very good, without an antenna. But the eye only closes all the way on the absolute strongest station, unless I connect an external antenna. Is there anything I can change to increase the sensitivity of the eye tube? Maybe a different value of a resistor? ... I would just like it better if the eye closed on weaker stations.
Tuning Eye Help - by Jamie - 03-10-2014, 10:47 AM
RE: Tuning Eye Help - by Mondial - 03-10-2014, 10:59 AM
RE: Tuning Eye Help - by Jamie - 03-10-2014, 11:21 AM
RE: Tuning Eye Help - by Mondial - 03-10-2014, 11:34 AM
RE: Tuning Eye Help - by morzh - 03-10-2014, 11:41 AM
RE: Tuning Eye Help - by Jamie - 03-10-2014, 01:57 PM
RE: Tuning Eye Help - by morzh - 03-10-2014, 03:34 PM
RE: Tuning Eye Help - by Mondial - 03-10-2014, 04:29 PM
RE: Tuning Eye Help - by Jamie - 03-10-2014, 05:32 PM
RE: Tuning Eye Help - by morzh - 03-10-2014, 05:36 PM
RE: Tuning Eye Help - by Jamie - 03-11-2014, 06:54 PM
RE: Tuning Eye Help - by morzh - 03-11-2014, 07:29 PM
RE: Tuning Eye Help - by Jamie - 03-11-2014, 07:43 PM
RE: Tuning Eye Help - by Mondial - 03-11-2014, 08:09 PM
RE: Tuning Eye Help - by Jamie - 03-11-2014, 08:46 PM
RE: Tuning Eye Help - by BrendaAnnD - 03-11-2014, 09:46 PM
RE: Tuning Eye Help - by Jamie - 03-13-2014, 10:17 AM
RE: Tuning Eye Help - by Dan Walker - 04-01-2014, 08:55 PM
RE: Tuning Eye Help - by Conelrad - 04-02-2014, 02:10 AM
RE: Tuning Eye Help - by Jamie - 04-02-2014, 10:40 AM
RE: Tuning Eye Help - by Randy H. - 06-16-2014, 05:36 PM
There are currently 4492 online users. [Complete List]
» 1 Member(s) | 4491 Guest(s)
