Philco 66
Here is what you do Mike,
Take her down to bare bones. dismantle the body and lay it flat on a padded surface. using a q-tip and some lacquer thinner brushing counter clockwise in 1" circles, remove the finish. should take about 4 hours if done right. Then remover exactly 1/100th of an inch of the top veneer using a dull hand planer. (very important so you don't get any pink elephants in the finish).........Ok wait, that might have been part of a dream last night?
Or you can just use Howards too. Icon_crazyIcon_crazy
I think I need to go back to bed for a while. Icon_lolIcon_lol
Philco 66 - by morzh - 02-24-2014, 09:51 PM
RE: Philco 66 - by skyscraper - 02-24-2014, 09:58 PM
RE: Philco 66 - by murf - 02-24-2014, 10:53 PM
RE: Philco 66 - by morzh - 02-24-2014, 11:05 PM
RE: Philco 66 - by murf - 02-24-2014, 11:28 PM
RE: Philco 66 - by morzh - 02-24-2014, 11:37 PM
RE: Philco 66 - by morzh - 03-11-2014, 09:41 PM
RE: Philco 66 - by murf - 03-11-2014, 10:22 PM
RE: Philco 66 - by gregb - 03-11-2014, 10:44 PM
RE: Philco 66 - by morzh - 03-11-2014, 11:05 PM
RE: Philco 66 - by gregb - 03-11-2014, 11:15 PM
RE: Philco 66 - by OldRestorer - 03-12-2014, 07:03 AM
RE: Philco 66 - by morzh - 03-12-2014, 08:42 AM
RE: Philco 66 - by Eric Adams - 03-12-2014, 09:58 AM
RE: Philco 66 - by morzh - 03-12-2014, 10:53 AM
RE: Philco 66 - by Eric Adams - 03-12-2014, 11:33 AM
RE: Philco 66 - by morzh - 03-12-2014, 02:45 PM
RE: Philco 66 - by Eric Adams - 03-12-2014, 04:35 PM
RE: Philco 66 - by OldRestorer - 03-13-2014, 11:41 AM
RE: Philco 66 - by jph14 - 04-04-2014, 09:50 AM
RE: Philco 66 - by Ron Ramirez - 04-04-2014, 10:00 AM
RE: Philco 66 - by morzh - 04-04-2014, 01:46 PM
RE: Philco 66 - by Ron Ramirez - 04-04-2014, 02:02 PM
RE: Philco 66 - by jph14 - 04-04-2014, 02:18 PM
RE: Philco 66 - by morzh - 04-04-2014, 06:48 PM
There are currently 6206 online users. [Complete List]
» 1 Member(s) | 6205 Guest(s)
