Threads: 242
City: West Bend, Wisconsin
Oh I wish I would've found that wire, Will. Would've made life so much easier! ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) Thanks for the tip.
Congrats on getting it to play for an extended time. I bet with Mondial's suggestion of a different #75 tube, the thunder will stop rolling and the sun will come out!
Users browsing this thread: 44 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 9620 online users. [Complete List] » 6 Member(s) | 9614 Guest(s)
