Philco 40-180 restoration completed!
DonS, I'm slowly gearing up to work on a 40-190 with the identical chassis. I've only seen a few of them about, of course... I'm trying to find out if I'm supposed to have any tube shields. Does your set have any?
Philco 40-180 restoration completed! - by DonS - 06-01-2008, 06:18 PM
[No subject] - by exray - 06-01-2008, 08:51 PM
[No subject] - by BDM - 06-01-2008, 11:02 PM
[No subject] - by DonS - 06-01-2008, 11:56 PM
[No subject] - by DeckApe - 07-01-2008, 02:08 PM
[No subject] - by Michael Dennis - 07-01-2008, 03:09 PM
[No subject] - by Ron Ramirez - 07-03-2008, 10:08 AM
[No subject] - by englishradioman - 07-12-2008, 06:53 PM
[No subject] - by DeckApe - 07-13-2008, 12:58 PM
[No subject] - by DonS - 07-15-2008, 12:30 PM
[No subject] - by DeckApe - 07-15-2008, 01:28 PM
