SW aerial
General rule of thumb is as high up as you can get it, Used a slingshot to get in up into the trees here. The longer the better it will work on lower frequencies. The ant I use most is about 120' long and up 35' or so. All I got is midget trees around.
A good ant for SW would be 60' of wire cut in the center and fed with 300 ohm twinlead. Up as high as you can get it, away from power lines and other noisy stuff.
SW aerial - by fields 100 - 03-11-2014, 08:46 AM
RE: SW aerial - by morzh - 03-11-2014, 01:46 PM
RE: SW aerial - by Art Hoch - 03-11-2014, 10:04 PM
RE: SW aerial - by captainslack - 03-12-2014, 02:21 PM
RE: SW aerial - by Eric T - 03-12-2014, 08:55 PM
RE: SW aerial - by Radioroslyn - 03-13-2014, 08:18 AM
RE: SW aerial - by fields 100 - 03-13-2014, 09:01 AM
RE: SW aerial - by David - 03-13-2014, 01:42 PM
RE: SW aerial - by Radioroslyn - 03-13-2014, 05:28 PM
RE: SW aerial - by fields 100 - 03-13-2014, 06:29 PM
RE: SW aerial - by fields 100 - 09-03-2014, 09:39 AM
RE: SW aerial - by morzh - 09-03-2014, 09:48 AM
RE: SW aerial - by fields 100 - 09-03-2014, 11:42 AM
RE: SW aerial - by morzh - 09-03-2014, 11:56 AM
RE: SW aerial - by Mondial - 09-03-2014, 02:12 PM
RE: SW aerial - by David - 09-05-2014, 03:51 PM
RE: SW aerial - by David - 09-05-2014, 06:14 PM
RE: SW aerial - by fields 100 - 09-16-2014, 06:25 PM
RE: SW aerial - by David - 09-17-2014, 09:04 AM
RE: SW aerial - by PhilcoJohn - 09-17-2014, 07:44 PM
RE: SW aerial - by fields 100 - 09-17-2014, 10:01 PM
RE: SW aerial - by Mondial - 09-17-2014, 10:08 PM
RE: SW aerial - by David - 09-19-2014, 08:17 PM
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
