SW aerial
@ Radioroslyn,
60 feet sounds good to me.Can be done. Please explain what does it mean "cut in the center and fed with 300 ohm twinlead"? Do you mean connecting 2 30 footers with a 300 ohm resistor at the top, then splice the wires together at the set? Thanks.
SW aerial - by fields 100 - 03-11-2014, 08:46 AM
RE: SW aerial - by morzh - 03-11-2014, 01:46 PM
RE: SW aerial - by Art Hoch - 03-11-2014, 10:04 PM
RE: SW aerial - by captainslack - 03-12-2014, 02:21 PM
RE: SW aerial - by Eric T - 03-12-2014, 08:55 PM
RE: SW aerial - by Radioroslyn - 03-13-2014, 08:18 AM
RE: SW aerial - by fields 100 - 03-13-2014, 09:01 AM
RE: SW aerial - by David - 03-13-2014, 01:42 PM
RE: SW aerial - by Radioroslyn - 03-13-2014, 05:28 PM
RE: SW aerial - by fields 100 - 03-13-2014, 06:29 PM
RE: SW aerial - by fields 100 - 09-03-2014, 09:39 AM
RE: SW aerial - by morzh - 09-03-2014, 09:48 AM
RE: SW aerial - by fields 100 - 09-03-2014, 11:42 AM
RE: SW aerial - by morzh - 09-03-2014, 11:56 AM
RE: SW aerial - by Mondial - 09-03-2014, 02:12 PM
RE: SW aerial - by David - 09-05-2014, 03:51 PM
RE: SW aerial - by David - 09-05-2014, 06:14 PM
RE: SW aerial - by fields 100 - 09-16-2014, 06:25 PM
RE: SW aerial - by David - 09-17-2014, 09:04 AM
RE: SW aerial - by PhilcoJohn - 09-17-2014, 07:44 PM
RE: SW aerial - by fields 100 - 09-17-2014, 10:01 PM
RE: SW aerial - by Mondial - 09-17-2014, 10:08 PM
RE: SW aerial - by David - 09-19-2014, 08:17 PM
There are currently 5027 online users. [Complete List]
» 3 Member(s) | 5024 Guest(s)
