The Fisher 440-T FM Receiver
Threads: 14
City: Irvington, NY
At his point I really think the LED is working as it should and the MPX decoder may need work or alignment. After all, you don't know if the MPX or stereo indicator worked properly before the bulb burned out either.
Do you hear any stereo effect when receiving the strong station? If there isn't enough 19 kHz signal to turn on the lamp fully, there isn't enough to activate the decoder circuit and you will only get mono.
RE: The Fisher 440-T FM Receiver - by Mondial - 03-13-2014, 09:07 PM
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
There are currently 5952 online users. [Complete List] » 1 Member(s) | 5951 Guest(s)
