46-1209 6v6gt hum and if question
Ok I ran wire to ground the tube socket and no more humm
Still have no radio at all not even static I do not have a signal generator so I don't think I can do an alignment
46-1209 6v6gt hum and if question - by philco4me - 03-13-2014, 06:35 PM
RE: 46-1209 6v6gt hum and if question - by morzh - 03-13-2014, 09:07 PM
RE: 46-1209 6v6gt hum and if question - by morzh - 03-13-2014, 10:14 PM
RE: 46-1209 6v6gt hum and if question - by morzh - 03-13-2014, 11:48 PM
RE: 46-1209 6v6gt hum and if question - by TV MAN - 03-14-2014, 09:21 AM
RE: 46-1209 6v6gt hum and if question - by philco4me - 03-14-2014, 11:58 AM
RE: 46-1209 6v6gt hum and if question - by morzh - 03-14-2014, 12:12 PM
RE: 46-1209 6v6gt hum and if question - by TV MAN - 03-14-2014, 02:24 PM
There are currently 10423 online users. [Complete List]
» 2 Member(s) | 10421 Guest(s)
