  • 1 Vote(s) - 1 Average
49-905 Mica Disease-FOUND IT!
After finishing (or so I thought) my 49-905, It has now started to make a crackling noise on AM only that sounds like the dreaded Mica disease. From the schematic I don't see any mica caps inside the AM IF cans. Any ideas?
http://www.nostalgiaair.org/PagesByModel...013674.pdf
Eric
The Villages, FL
49-905 Mica Disease-FOUND IT! - by Eric Adams - 03-14-2014, 12:44 PM
RE: 49-905 Mica Disease - by morzh - 03-14-2014, 01:13 PM
RE: 49-905 Mica Disease - by Eric Adams - 03-14-2014, 01:15 PM
RE: 49-905 Mica Disease - by Mondial - 03-14-2014, 01:58 PM
RE: 49-905 Mica Disease - by Eric Adams - 03-14-2014, 02:07 PM
RE: 49-905 Mica Disease - by Mondial - 03-14-2014, 02:11 PM
RE: 49-905 Mica Disease - by Eric Adams - 03-14-2014, 02:14 PM
RE: 49-905 Mica Disease - by Mondial - 03-14-2014, 02:31 PM
RE: 49-905 Mica Disease - by Eric Adams - 03-14-2014, 05:14 PM
RE: 49-905 Mica Disease - by Mondial - 03-14-2014, 06:02 PM
RE: 49-905 Mica Disease - by morzh - 03-14-2014, 08:22 PM
RE: 49-905 Mica Disease-FOUND IT! - by Eric Adams - 03-14-2014, 10:38 PM
RE: 49-905 Mica Disease-FOUND IT! - by Eric Adams - 03-15-2014, 04:33 PM
RE: 49-905 Mica Disease-FOUND IT! - by morzh - 03-15-2014, 09:03 PM
RE: 49-905 Mica Disease-FOUND IT! - by Eric Adams - 03-19-2014, 07:45 PM
RE: 49-905 Mica Disease-FOUND IT! - by Arran - 03-20-2014, 12:49 AM
RE: 49-905 Mica Disease-FOUND IT! - by Eric Adams - 03-20-2014, 01:09 AM
There are currently 9768 online users. [Complete List]
» 1 Member(s) | 9767 Guest(s)
