The Fisher 4400 FM Receiver
Threads: 14
City: Irvington, NY
Ron, you can achieve the same result without dissipating all that power if you reduce the value of the electrolytic to ground. This cap is what is causing the slow response. What is the value in the 440?
With a smaller value cap, the response time can be made as small as you like, with a higher value resistor that won't consume so much power.
RE: The Fisher 4400 FM Receiver - by Mondial - 03-15-2014, 11:25 AM
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Var resistor id
There are currently 6493 online users. [Complete List] » 2 Member(s) | 6491 Guest(s)
