42-355 field coil gets very warm
Sometimes your utility will be nice enough to do that. I've had the same issue before and they complied. But often is the case when they come out on a hot sunny day and say "harrumph, its 124 volts - nothing wrong with that" oblivious to the fact it may be reaching 130 at night when there's less load.
We had a spell here a few years back that had me at 127-128 in the evening and it took its toll on light bulbs and a few old radio xfmrs. The issue has since been corrected (it wasn't my local xfmr) but during that time I stocked up on some bargain-priced 50 watt / 18 ohm Dale chassis mount resistors. They will drop about 6-10 volts on most radios.
I could spare any of you fellows a couple for the mailing cost. Call it $1 for one or 1.50 fer two. Easier than winding your own Icon_smile
-ex
42-355 field coil gets very warm - by Guest - 06-28-2008, 07:44 PM
[No subject] - by Texasrocker - 06-29-2008, 01:33 AM
[No subject] - by Guest - 06-29-2008, 11:26 AM
[No subject] - by etech - 06-29-2008, 05:48 PM
[No subject] - by Guest - 06-30-2008, 10:00 PM
[No subject] - by Texasrocker - 07-01-2008, 01:21 AM
[No subject] - by justlrnin - 07-01-2008, 07:41 AM
[No subject] - by Ron Ramirez - 07-03-2008, 10:28 AM
[No subject] - by etech - 07-03-2008, 09:00 PM
[No subject] - by Guest - 07-04-2008, 01:46 PM
[No subject] - by etech - 07-04-2008, 06:07 PM
[No subject] - by Ron Ramirez - 07-04-2008, 06:57 PM
[No subject] - by BDM - 07-04-2008, 07:37 PM
[No subject] - by etech - 07-04-2008, 09:06 PM
[No subject] - by Texasrocker - 07-12-2008, 03:11 AM
[No subject] - by etech - 07-12-2008, 09:50 AM
[No subject] - by justlrnin - 07-14-2008, 06:36 PM
[No subject] - by FStephenMasek - 07-14-2008, 06:50 PM
[No subject] - by exray - 07-14-2008, 08:57 PM
[No subject] - by etech - 07-14-2008, 09:27 PM
[No subject] - by BDM - 07-15-2008, 12:41 AM
[No subject] - by exray - 07-15-2008, 02:47 AM
