Radio Daze PHILCO Decals Corrected!
BTW there is no decal for the bandswitch on the 37-116. The 37-116 was Philco's next to the top of the line for 1937. It's a very nice set and a great player once it's been serviced. Please do have someone look it over before pressing into service. As Steve said.
RE: Radio Daze PHILCO Decals Corrected! - by Larry S. - 03-15-2014, 12:04 PM
RE: Radio Daze PHILCO Decals Corrected! - by Radioroslyn - 03-15-2014, 04:12 PM
There are currently 8790 online users. [Complete List]
» 3 Member(s) | 8787 Guest(s)
