Threads: 242
City: West Bend, Wisconsin
Just for comparison, I went with a 7.5K resistor on the 36 cathode and a 700 pF cap. I had a .0015 mfd. in originally, but when I was having all of that trouble with getting nothing but shortwave, I found a 700 pF and changed it out. I doubt it would've made much difference.
Users browsing this thread: 38 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10619 online users. [Complete List] » 2 Member(s) | 10617 Guest(s)
