useing Correct color for Radio
hmmm, didn't look cherry to me... the color is a walnut. Does seem to look that way a bit in the picture...Maybe the picture shows it that way a bit. Maybe the fluorescent light does that, not sure. i will take more pics as I finish it and hopefully it wont look cherry then. Thanks Morzh and Greg, I appreciate the thoughts.
useing Correct color for Radio - by Warren - 03-09-2014, 05:59 PM
RE: useing Correct color for Radio - by morzh - 03-09-2014, 08:11 PM
RE: useing Correct color for Radio - by Warren - 03-09-2014, 08:31 PM
RE: useing Correct color for Radio - by Warren - 03-09-2014, 11:06 PM
RE: useing Correct color for Radio - by Warren - 03-09-2014, 11:55 PM
RE: useing Correct color for Radio - by morzh - 03-10-2014, 10:29 AM
RE: useing Correct color for Radio - by Jamie - 03-10-2014, 02:19 PM
RE: useing Correct color for Radio - by morzh - 03-10-2014, 03:33 PM
RE: useing Correct color for Radio - by Warren - 03-10-2014, 05:51 PM
RE: useing Correct color for Radio - by Warren - 03-15-2014, 07:27 PM
RE: useing Correct color for Radio - by morzh - 03-15-2014, 09:07 PM
RE: useing Correct color for Radio - by Warren - 03-15-2014, 11:25 PM
RE: useing Correct color for Radio - by gregb - 03-15-2014, 11:34 PM
RE: useing Correct color for Radio - by TheBakery - 04-28-2014, 02:39 PM
Philco 91 Tuning Condenser
There are currently 6622 online users. [Complete List]
» 2 Member(s) | 6620 Guest(s)
