useing Correct color for Radio
The cabinet looks great Warren! I think it is probably the lighting that makes the colors appear off to some. I know when I take pictures for RM I notice a color shift between natural, flash, and florescent lighting.
useing Correct color for Radio - by Warren - 03-09-2014, 05:59 PM
RE: useing Correct color for Radio - by morzh - 03-09-2014, 08:11 PM
RE: useing Correct color for Radio - by Warren - 03-09-2014, 08:31 PM
RE: useing Correct color for Radio - by Warren - 03-09-2014, 11:06 PM
RE: useing Correct color for Radio - by Warren - 03-09-2014, 11:55 PM
RE: useing Correct color for Radio - by morzh - 03-10-2014, 10:29 AM
RE: useing Correct color for Radio - by Jamie - 03-10-2014, 02:19 PM
RE: useing Correct color for Radio - by morzh - 03-10-2014, 03:33 PM
RE: useing Correct color for Radio - by Warren - 03-10-2014, 05:51 PM
RE: useing Correct color for Radio - by Warren - 03-15-2014, 07:27 PM
RE: useing Correct color for Radio - by morzh - 03-15-2014, 09:07 PM
RE: useing Correct color for Radio - by Warren - 03-15-2014, 11:25 PM
RE: useing Correct color for Radio - by gregb - 03-15-2014, 11:34 PM
RE: useing Correct color for Radio - by Eliot Ness - 03-16-2014, 09:05 AM
RE: useing Correct color for Radio - by TheBakery - 04-28-2014, 02:39 PM
Philco 91 Tuning Condenser
There are currently 6877 online users. [Complete List]
» 2 Member(s) | 6875 Guest(s)
