Stromberg Carlson 535M
I know some of you have early 40's sets with Fm bands, what have you done as far as restoring the fm . Did you recap the chassis and what were your expectations. Did you receive any stations or am I just wasting my time. Here is a picture of the chassis before any restore.[Image: http://i1281.photobucket.com/albums/a508...156849.jpg]
Stromberg Carlson 535M - by Ronin61 - 03-16-2014, 05:07 PM
RE: Stromberg Carlson 535M - by skyscraper - 03-16-2014, 05:16 PM
RE: Stromberg Carlson 535M - by morzh - 03-16-2014, 07:58 PM
RE: Stromberg Carlson 535M - by Arran - 03-16-2014, 10:31 PM
RE: Stromberg Carlson 535M - by TA Forbes - 03-19-2014, 10:42 PM
RE: Stromberg Carlson 535M - by morzh - 03-19-2014, 11:36 PM
RE: Stromberg Carlson 535M - by rocketeer - 03-20-2014, 07:16 PM
RE: Stromberg Carlson 535M - by Penthode - 04-15-2014, 08:45 PM
RE: Stromberg Carlson 535M - by TA Forbes - 04-15-2014, 11:38 PM
RE: Stromberg Carlson 535M - by Penthode - 04-16-2014, 07:29 PM
RE: Stromberg Carlson 535M - by TA Forbes - 04-17-2014, 11:45 AM
