Stromberg Carlson 535M
You do not necessarily need a transmitter, you could use a converter.
http://www.somerset.net/arm/reprints/one...ter_p1.gif
http://www.somerset.net/arm/radio_age_july99.html
Or this guy uses a modified TV tuner to convert FM band. His Z sounds pretty nice even over youtube.
The Zenith I just bought has the same 1941 FM band. Will have to deal with that when the restoration is done.
Stromberg Carlson 535M - by Ronin61 - 03-16-2014, 05:07 PM
RE: Stromberg Carlson 535M - by skyscraper - 03-16-2014, 05:16 PM
RE: Stromberg Carlson 535M - by morzh - 03-16-2014, 07:58 PM
RE: Stromberg Carlson 535M - by Arran - 03-16-2014, 10:31 PM
RE: Stromberg Carlson 535M - by TA Forbes - 03-19-2014, 10:42 PM
RE: Stromberg Carlson 535M - by morzh - 03-19-2014, 11:36 PM
RE: Stromberg Carlson 535M - by rocketeer - 03-20-2014, 07:16 PM
RE: Stromberg Carlson 535M - by Penthode - 04-15-2014, 08:45 PM
RE: Stromberg Carlson 535M - by TA Forbes - 04-15-2014, 11:38 PM
RE: Stromberg Carlson 535M - by Penthode - 04-16-2014, 07:29 PM
RE: Stromberg Carlson 535M - by TA Forbes - 04-17-2014, 11:45 AM
