Stromberg Carlson 535M
I think that you may be able to receive some ham stuff on at least part of the old FM band, but for the most part there isn't anything on it. On the other hand if you can come up with a part 15 transmitter that operates on that band it's pretty much an open channel.
Stromberg Carlson 535M - by Ronin61 - 03-16-2014, 05:07 PM
RE: Stromberg Carlson 535M - by skyscraper - 03-16-2014, 05:16 PM
RE: Stromberg Carlson 535M - by morzh - 03-16-2014, 07:58 PM
RE: Stromberg Carlson 535M - by Arran - 03-16-2014, 10:31 PM
RE: Stromberg Carlson 535M - by TA Forbes - 03-19-2014, 10:42 PM
RE: Stromberg Carlson 535M - by morzh - 03-19-2014, 11:36 PM
RE: Stromberg Carlson 535M - by rocketeer - 03-20-2014, 07:16 PM
RE: Stromberg Carlson 535M - by Penthode - 04-15-2014, 08:45 PM
RE: Stromberg Carlson 535M - by TA Forbes - 04-15-2014, 11:38 PM
RE: Stromberg Carlson 535M - by Penthode - 04-16-2014, 07:29 PM
RE: Stromberg Carlson 535M - by TA Forbes - 04-17-2014, 11:45 AM
There are currently 5845 online users. [Complete List]
» 1 Member(s) | 5844 Guest(s)
