What Is The Difference Between Code 121 and 122?
Mike,
You raise an interesting question (for me at least). I have a 48-460 which shows on the data tag "Code 122". While I've found plenty of data for the "code 121" version I've yet to be able to determine the difference between that and the code 122 which I have.
John
[No subject] - by Carl Travis - 07-14-2008, 07:06 PM
[No subject] - by Michael Dennis - 07-14-2008, 07:30 PM
[No subject] - by phly guy - 07-17-2008, 12:17 AM
[No subject] - by Chuck Schwark - 07-17-2008, 09:40 AM
[No subject] - by Michael Dennis - 07-18-2008, 02:03 PM
[No subject] - by Chuck Schwark - 07-18-2008, 02:31 PM
[No subject] - by Ron Ramirez - 07-18-2008, 07:40 PM
[No subject] - by Michael Dennis - 07-18-2008, 08:27 PM
[No subject] - by Ron Ramirez - 07-18-2008, 10:23 PM
[No subject] - by Michael Dennis - 07-18-2008, 10:29 PM
[No subject] - by Michael Dennis - 07-18-2008, 11:24 PM
There are currently 10036 online users. [Complete List]
» 3 Member(s) | 10033 Guest(s)
