what philco chassis is this?
Thats a lot of schematic changes. So model 89 code 123 is the model number but is it a table top model or were they interchangeable.. I guess I'd have to know how to read schematics to tell which schematic is correct huh..The seller forgot to include the speaker so I had to email them.
Thanks for the info and link
Kirk
what philco chassis is this? - by OldRestorer - 03-17-2014, 11:42 AM
RE: what philco chassis is this? - by gregb - 03-17-2014, 11:48 AM
RE: what philco chassis is this? - by klondike98 - 03-17-2014, 11:59 AM
RE: what philco chassis is this? - by skyscraper - 03-17-2014, 12:02 PM
RE: what philco chassis is this? - by OldRestorer - 03-17-2014, 12:08 PM
RE: what philco chassis is this? - by skyscraper - 03-17-2014, 12:11 PM
RE: what philco chassis is this? - by Jamie - 03-17-2014, 04:12 PM
RE: what philco chassis is this? - by OldRestorer - 03-17-2014, 06:44 PM
Philco 91 Tuning Condenser
