Photo Finish Restoration
The practice session seemed to go well, so I decided to proceed. I used Elmer's Wood Glue, and spread the glue all over the back of the stripes. You cannot miss even a small area, you must coat the back of the paper entirely. ...
Then I stuck it on the cabinet...
Photo Finish Restoration - by Jamie - 03-17-2014, 03:36 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:40 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:43 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:46 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:50 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:55 PM
RE: Photo Finish Restoration - by klondike98 - 03-17-2014, 04:34 PM
RE: Photo Finish Restoration - by OldRestorer - 03-17-2014, 05:56 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 06:23 PM
RE: Photo Finish Restoration - by shaler78 - 03-17-2014, 06:51 PM
RE: Photo Finish Restoration - by EricS - 03-29-2014, 07:17 PM
RE: Photo Finish Restoration - by Jamie - 03-30-2014, 08:26 AM
RE: Photo Finish Restoration - by klondike98 - 04-21-2014, 12:37 PM
RE: Photo Finish Restoration - by Jamie - 04-21-2014, 05:39 PM
Philco 91 Tuning Condenser
There are currently 9341 online users. [Complete List]
» 1 Member(s) | 9340 Guest(s)
