Photo Finish Restoration
Alright.. lookin good!..Allow it to dry! ...
Next up was just to use regular refinishing technique. There are already threads on this, so I will skip those steps. Basically, I sprayed a light coat of universal walnut over the entire cabinet (including my paper finish.).. Then, I taped off the main cabinet and did the edges with Extra Dark Walnut. This was followed up with a few coats of Clear Gloss.
Final Result....
Vs
Original look that was desired...
Not too shabby!..
Photo Finish Restoration - by Jamie - 03-17-2014, 03:36 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:40 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:43 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:46 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:50 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:55 PM
RE: Photo Finish Restoration - by klondike98 - 03-17-2014, 04:34 PM
RE: Photo Finish Restoration - by OldRestorer - 03-17-2014, 05:56 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 06:23 PM
RE: Photo Finish Restoration - by shaler78 - 03-17-2014, 06:51 PM
RE: Photo Finish Restoration - by EricS - 03-29-2014, 07:17 PM
RE: Photo Finish Restoration - by Jamie - 03-30-2014, 08:26 AM
RE: Photo Finish Restoration - by klondike98 - 04-21-2014, 12:37 PM
RE: Photo Finish Restoration - by Jamie - 04-21-2014, 05:39 PM
Philco 91 Tuning Condenser
