Photo Finish Restoration
Thanks PP, I have to do a similar strip on a Wards Airline console, about 4 inches wide x 17" long. I've read all the threads on doing this but always nice to see it done in detail. Icon_clapIcon_clapIcon_clap
Photo Finish Restoration - by Jamie - 03-17-2014, 03:36 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:40 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:43 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:46 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:50 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 03:55 PM
RE: Photo Finish Restoration - by klondike98 - 03-17-2014, 04:34 PM
RE: Photo Finish Restoration - by OldRestorer - 03-17-2014, 05:56 PM
RE: Photo Finish Restoration - by Jamie - 03-17-2014, 06:23 PM
RE: Photo Finish Restoration - by shaler78 - 03-17-2014, 06:51 PM
RE: Photo Finish Restoration - by EricS - 03-29-2014, 07:17 PM
RE: Photo Finish Restoration - by Jamie - 03-30-2014, 08:26 AM
RE: Photo Finish Restoration - by klondike98 - 04-21-2014, 12:37 PM
RE: Photo Finish Restoration - by Jamie - 04-21-2014, 05:39 PM
Philco 91 Tuning Condenser
