Sears 6050 Re-stuffing Ecap question still need answer
I am re-repairing my 6050 and someone at one time just threw a 50 uf Ecap under the chassis to replace the 40 20 that was there.
I had started by just replacing the 50 with a new 50 but was still getting a loud unchanging buzzing from the speaker so I ditched that idea.
I have removed the Ecap and have put in the new 47 and 22 Ecaps to their marked terminals but want to make sure I am getting the grounding right.
I have both negatives twisted and going to one of the outer twist lock terminals of the can. the can says negative is the can so is this correct?
Lastly, Where they put in the replacement cap is now not needed so I just clip it out and don't need to do anything else right?
Here are some pics:
Sears 6050 Re-stuffing Ecap question still need answer - by OldRestorer - 03-17-2014, 06:11 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 3637 online users. [Complete List]
» 3 Member(s) | 3634 Guest(s)
