what philco chassis is this?
Right of passage huh?
I was just gonna sell it since I only wanted the knobs. I dont want to have to search for a cabinet for it and I cant follow the wires to find out what schematic it uses and blah blah blah.
what philco chassis is this? - by OldRestorer - 03-17-2014, 11:42 AM
RE: what philco chassis is this? - by gregb - 03-17-2014, 11:48 AM
RE: what philco chassis is this? - by klondike98 - 03-17-2014, 11:59 AM
RE: what philco chassis is this? - by skyscraper - 03-17-2014, 12:02 PM
RE: what philco chassis is this? - by OldRestorer - 03-17-2014, 12:08 PM
RE: what philco chassis is this? - by skyscraper - 03-17-2014, 12:11 PM
RE: what philco chassis is this? - by Jamie - 03-17-2014, 04:12 PM
RE: what philco chassis is this? - by OldRestorer - 03-17-2014, 06:44 PM
There are currently 4260 online users. [Complete List]
» 1 Member(s) | 4259 Guest(s)
