Who has old dog bone/cartridge type resistors?
I have a cigar box or two of dogbones, and if you only need a few, I'm sure I can spare them. Trick is, they may not measure within tolerance, and if I have to go through a bunch with an ohmmeter it gets old fast. If the exact value doesn't matter, drop me a line: adouglas (at) gis.net
Who has old dog bone/cartridge type resistors? - by tom2 - 07-04-2008, 08:13 PM
[No subject] - by gary rabbitt - 07-06-2008, 11:36 PM
Alternative brand? - by tom2 - 07-10-2008, 07:54 PM
[No subject] - by exray - 07-10-2008, 08:46 PM
[No subject] - by tom2 - 07-11-2008, 04:09 PM
[No subject] - by Syl - 07-11-2008, 08:36 PM
[No subject] - by Ron Ramirez - 07-11-2008, 08:42 PM
[No subject] - by Alan Douglas - 07-17-2008, 06:05 PM
There are currently 8250 online users. [Complete List]
» 1 Member(s) | 8249 Guest(s)
