Model 610 electrolytic condensers
Thanks for the pic! It helps a lot. Looks like mine has had a couple of resistors replaced also. On the #23 bakelite, they have cut the middle lead off on mine, but I dont see where they have soldered anything in its place. Weird. The electrolytic caps, one has 450v stamped on it, but it wouldnt hurt anything to go 500v like Morzh mentioned.
Tim
Model 610 electrolytic condensers - by Kestas - 03-02-2014, 06:54 PM
RE: Model 610 electrolytic condensers - by morzh - 03-02-2014, 08:16 PM
RE: Model 610 electrolytic condensers - by TV MAN - 03-05-2014, 10:47 AM
RE: Model 610 electrolytic condensers - by Kestas - 03-05-2014, 01:56 PM
RE: Model 610 electrolytic condensers - by TV MAN - 03-05-2014, 03:17 PM
RE: Model 610 electrolytic condensers - by Kestas - 03-05-2014, 06:32 PM
RE: Model 610 electrolytic condensers - by TV MAN - 03-16-2014, 03:52 PM
RE: Model 610 electrolytic condensers - by Kestas - 03-17-2014, 09:40 PM
RE: Model 610 electrolytic condensers - by TV MAN - 03-18-2014, 10:51 AM
There are currently 8377 online users. [Complete List]
» 2 Member(s) | 8375 Guest(s)
