38-4 fake?
I think you might be talking about the Automatic tuning dial with "Magnetic Tuning." Here is an article from Chuck Schwark's web site that should answer most of your questions.
http://www.philcorepairbench.com/autodial/index.htm
John Honeycutt
38-4 fake? - by plymouth53 - 03-18-2014, 12:58 PM
RE: 38-4 fake? - by Raleigh - 03-18-2014, 01:06 PM
RE: 38-4 fake? - by skyscraper - 03-18-2014, 01:12 PM
RE: 38-4 fake? - by klondike98 - 03-18-2014, 01:18 PM
RE: 38-4 fake? - by plymouth53 - 03-18-2014, 04:24 PM
RE: 38-4 fake? - by skyscraper - 03-18-2014, 04:44 PM
Philco 91 Tuning Condenser
