help with Philco phonograph
Try to place it in Philco Electronic restoration first, but if no one answered it might be due top the fact no one has anything on it.
You did not list the model; I tried C5-1555 and found nothing.
help with Philco phonograph - by Shanez24 - 03-16-2014, 05:54 PM
RE: help with Philco phonograph - by Shanez24 - 03-18-2014, 01:31 PM
RE: help with Philco phonograph - by morzh - 03-18-2014, 01:57 PM
RE: help with Philco phonograph - by gregb - 03-18-2014, 02:38 PM
RE: help with Philco phonograph - by Shanez24 - 03-18-2014, 03:58 PM
RE: help with Philco phonograph - by klondike98 - 03-18-2014, 04:20 PM
RE: help with Philco phonograph - by Shanez24 - 03-18-2014, 04:31 PM
Philco 91 Tuning Condenser
