  • 1 Vote(s) - 5 Average
Philco model 70 rebuild - by Tim P.
#68
Tim, with the specs on the pots and if you can't get them working properly, it might be time to get in contact with Mark who assembles pots from new stock. He will need the resistance and taper.
Jerry
Philco model 70 rebuild - by Tim P. - by TV MAN - 01-29-2014, 11:46 AM
RE: Philco model 70 rebuild - by Tim P. - by jerryhawthorne - 03-18-2014, 07:03 PM
Users browsing this thread: 25 Guest(s)
There are currently 11341 online users. [Complete List]
» 2 Member(s) | 11339 Guest(s)
