  • 1 Vote(s) - 5 Average
Philco model 70 rebuild - by Tim P.
#69
Not a bad idea, I did not know he does that. Good source for the future.
Philco model 70 rebuild - by Tim P. - by TV MAN - 01-29-2014, 11:46 AM
RE: Philco model 70 rebuild - by Tim P. - by morzh - 03-18-2014, 08:06 PM
Users browsing this thread: 22 Guest(s)
There are currently 11280 online users. [Complete List]
» 2 Member(s) | 11278 Guest(s)
