46-1201 CAP QUESTION
I have another working player and substituted the tubes to confirm they work fine. The other one works perfect as I restored it a few years ago with all new caps, etc. The new unit works on the phono, so I know the amp is fine. The volume control also responds on the radio side, but no stations received. I never did voltages before, but now is a good time to give it a try.
46-1201 CAP QUESTION - by davidff - 03-13-2014, 09:53 AM
RE: 46-1201 CAP QUESTION - by morzh - 03-13-2014, 10:15 AM
RE: 46-1201 CAP QUESTION - by codefox1 - 03-17-2014, 09:53 AM
RE: 46-1201 CAP QUESTION - by davidff - 03-19-2014, 08:06 AM
RE: 46-1201 CAP QUESTION - by TV MAN - 03-19-2014, 09:44 AM
RE: 46-1201 CAP QUESTION - by davidff - 03-19-2014, 11:22 AM
RE: 46-1201 CAP QUESTION - by morzh - 03-19-2014, 11:36 AM
RE: 46-1201 CAP QUESTION - by davidff - 03-19-2014, 01:06 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-19-2014, 01:25 PM
RE: 46-1201 CAP QUESTION - by davidff - 03-24-2014, 10:26 AM
RE: 46-1201 CAP QUESTION - by Eliot Ness - 03-24-2014, 11:26 AM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 11:50 AM
RE: 46-1201 CAP QUESTION - by Eliot Ness - 03-24-2014, 01:31 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 02:30 PM
RE: 46-1201 CAP QUESTION - by Warren - 03-24-2014, 03:36 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 04:18 PM
RE: 46-1201 CAP QUESTION - by Warren - 03-24-2014, 07:54 PM
RE: 46-1201 CAP QUESTION - by morzh - 03-24-2014, 08:58 PM
RE: 46-1201 CAP QUESTION - by Warren - 03-24-2014, 11:48 PM
There are currently 9307 online users. [Complete List]
» 1 Member(s) | 9306 Guest(s)
