What Is The Difference Between Code 121 and 122?
Aha, so that's what a type 77 does. I wondered because I'm supposed to be getting a couple in a bulk tube deal I won on ebay. Of course it's never a done deal until the items you won arrive intact. Paying for an item, even winning an auction is easy, but church ain't over 'till the fat lady sings. These two type 77's are Arcturas NOS and I wonder if they're blue glass envelopes. They're supposed to have never been removed from the boxes and I think Arcturas had some of the coolest tube box art.
Still no score, Fightin' Amish vs. Quaker State.
Mike
[No subject] - by Carl Travis - 07-14-2008, 07:06 PM
[No subject] - by Michael Dennis - 07-14-2008, 07:30 PM
[No subject] - by phly guy - 07-17-2008, 12:17 AM
[No subject] - by Chuck Schwark - 07-17-2008, 09:40 AM
[No subject] - by Michael Dennis - 07-18-2008, 02:03 PM
[No subject] - by Chuck Schwark - 07-18-2008, 02:31 PM
[No subject] - by Ron Ramirez - 07-18-2008, 07:40 PM
[No subject] - by Michael Dennis - 07-18-2008, 08:27 PM
[No subject] - by Ron Ramirez - 07-18-2008, 10:23 PM
[No subject] - by Michael Dennis - 07-18-2008, 10:29 PM
[No subject] - by Michael Dennis - 07-18-2008, 11:24 PM
There are currently 10089 online users. [Complete List]
» 2 Member(s) | 10087 Guest(s)
