  • 1 Vote(s) - 1 Average
49-905 Mica Disease-FOUND IT!
Eric, don't throw that old can away. It is one of the easier ones to cut out the old mica and place new caps on the outside. Save it you may need it. Of all the cans that I repair, that type was pretty easy to get a repair style figured for it.
Don
49-905 Mica Disease-FOUND IT! - by Eric Adams - 03-14-2014, 12:44 PM
RE: 49-905 Mica Disease - by morzh - 03-14-2014, 01:13 PM
RE: 49-905 Mica Disease - by Eric Adams - 03-14-2014, 01:15 PM
RE: 49-905 Mica Disease - by Mondial - 03-14-2014, 01:58 PM
RE: 49-905 Mica Disease - by Eric Adams - 03-14-2014, 02:07 PM
RE: 49-905 Mica Disease - by Mondial - 03-14-2014, 02:11 PM
RE: 49-905 Mica Disease - by Eric Adams - 03-14-2014, 02:14 PM
RE: 49-905 Mica Disease - by Mondial - 03-14-2014, 02:31 PM
RE: 49-905 Mica Disease - by Eric Adams - 03-14-2014, 05:14 PM
RE: 49-905 Mica Disease - by Mondial - 03-14-2014, 06:02 PM
RE: 49-905 Mica Disease - by morzh - 03-14-2014, 08:22 PM
RE: 49-905 Mica Disease-FOUND IT! - by Eric Adams - 03-14-2014, 10:38 PM
RE: 49-905 Mica Disease-FOUND IT! - by Eric Adams - 03-15-2014, 04:33 PM
RE: 49-905 Mica Disease-FOUND IT! - by morzh - 03-15-2014, 09:03 PM
RE: 49-905 Mica Disease-FOUND IT! - by Don Ferguson - 03-19-2014, 07:18 PM
RE: 49-905 Mica Disease-FOUND IT! - by Eric Adams - 03-19-2014, 07:45 PM
RE: 49-905 Mica Disease-FOUND IT! - by Arran - 03-20-2014, 12:49 AM
RE: 49-905 Mica Disease-FOUND IT! - by Eric Adams - 03-20-2014, 01:09 AM
There are currently 10155 online users. [Complete List]
» 1 Member(s) | 10154 Guest(s)
