Stromberg Carlson 535M
The FM circuitry on any set can be finicky to work on. You want to pay attention to lead dress and length and do NOT get creative with placement of components.
The FM band on my Stromberg Carlson 1025 is 21-99 MHz. I discovered that by mindlessly, and I mean that literally, screwing with the FM alignment AND experimenting with antennas that I can pick up several "modern" FM band stations. I believe that I am picking up harmonics, but they come in in an acceptable manner.
Stromberg Carlson 535M - by Ronin61 - 03-16-2014, 05:07 PM
RE: Stromberg Carlson 535M - by skyscraper - 03-16-2014, 05:16 PM
RE: Stromberg Carlson 535M - by morzh - 03-16-2014, 07:58 PM
RE: Stromberg Carlson 535M - by Arran - 03-16-2014, 10:31 PM
RE: Stromberg Carlson 535M - by TA Forbes - 03-19-2014, 10:42 PM
RE: Stromberg Carlson 535M - by morzh - 03-19-2014, 11:36 PM
RE: Stromberg Carlson 535M - by rocketeer - 03-20-2014, 07:16 PM
RE: Stromberg Carlson 535M - by Penthode - 04-15-2014, 08:45 PM
RE: Stromberg Carlson 535M - by TA Forbes - 04-15-2014, 11:38 PM
RE: Stromberg Carlson 535M - by Penthode - 04-16-2014, 07:29 PM
RE: Stromberg Carlson 535M - by TA Forbes - 04-17-2014, 11:45 AM
