An Old Dog learns something new.
Yes, I'm aware. I usually open up the aroma and taste with a tiny splash
of water with a calibrated right handed swirl, once in the proper glass.
8)
Chuck
An Old Dog learns something new. - by TA Forbes - 03-19-2014, 10:14 PM
RE: An Old Dog learns something new. - by morzh - 03-19-2014, 11:30 PM
RE: An Old Dog learns something new. - by morzh - 03-20-2014, 10:39 AM
RE: An Old Dog learns something new. - by morzh - 03-20-2014, 01:25 PM
RE: An Old Dog learns something new. - by morzh - 03-20-2014, 02:57 PM
RE: An Old Dog learns something new. - by Chuck Schwark - 03-20-2014, 04:38 PM
RE: An Old Dog learns something new. - by TimC - 03-21-2014, 10:59 AM
RE: An Old Dog learns something new. - by Arran - 03-21-2014, 11:43 PM
RE: An Old Dog learns something new. - by morzh - 03-22-2014, 09:32 AM
RE: An Old Dog learns something new. - by Jamie - 03-22-2014, 04:40 PM
RE: An Old Dog learns something new. - by GarySP - 03-23-2014, 10:54 PM
RE: An Old Dog learns something new. - by morzh - 03-24-2014, 12:01 PM
RE: An Old Dog learns something new. - by Arran - 03-24-2014, 11:25 PM
RE: An Old Dog learns something new. - by morzh - 03-25-2014, 09:59 AM
Philco 91 Tuning Condenser
