Philco PT-69 (Done), 38-62 (Done) & 41-22CL Resto Chronicles
Looks really good!! Were you able to get it working?
Gregb
RE: Philco PT-49 & Philco 38-62 Resto Chronicles - by gregb - 03-21-2014, 01:45 PM
Philco 91 Tuning Condenser
There are currently 8775 online users. [Complete List]
» 1 Member(s) | 8774 Guest(s)
