Philco model 610 rebuild - by Tim P.
Good luck with your rebuild - I know those schematic errors threw me off the scent a bit !
Philco model 610 rebuild - by Tim P. - by TV MAN - 03-16-2014, 04:12 PM
RE: Philco model 610 rebuild - by Tim P. - by Chris Cusick - 03-21-2014, 02:15 PM
Users browsing this thread: 20 Guest(s)
The speaker table error?
Philco 70 antenna lead
