48-460 squeal
Quote:The only thing I can't fathom is how one hooks up an antenna to a tuning gang other than on purpose.
Well, perhaps the person who replaced the antenna didn't know how to hook it up? .. I am just taking a wild guess. If the alignment has no effect on the squeal, and it isn't the wiring, then what could it be? Someone replaced the antenna - that is the only clue.
48-460 squeal - by Eric Adams - 03-20-2014, 01:16 AM
RE: 48-460 squeal - by murf - 03-20-2014, 06:42 AM
RE: 48-460 squeal - by Ron Ramirez - 03-20-2014, 08:29 AM
RE: 48-460 squeal - by Chuck Schwark - 03-20-2014, 09:07 AM
RE: 48-460 squeal - by Eric Adams - 03-20-2014, 09:28 AM
RE: 48-460 squeal - by morzh - 03-20-2014, 10:48 AM
RE: 48-460 squeal - by Eric Adams - 03-20-2014, 10:57 AM
RE: 48-460 squeal - by Eric Adams - 03-20-2014, 11:32 AM
RE: 48-460 squeal - by morzh - 03-20-2014, 01:27 PM
RE: 48-460 squeal - by Eric Adams - 03-20-2014, 07:10 PM
RE: 48-460 squeal - by morzh - 03-20-2014, 07:51 PM
RE: 48-460 squeal - by Eric Adams - 03-20-2014, 08:41 PM
RE: 48-460 squeal - by morzh - 03-20-2014, 09:55 PM
RE: 48-460 squeal - by Eric Adams - 03-21-2014, 10:09 AM
RE: 48-460 squeal - by Jamie - 03-21-2014, 10:37 AM
RE: 48-460 squeal - by Eric Adams - 03-21-2014, 06:32 PM
RE: 48-460 squeal - by Jamie - 03-22-2014, 04:45 PM
RE: 48-460 squeal - by morzh - 03-22-2014, 05:01 PM
RE: 48-460 squeal - by Eric Adams - 03-22-2014, 05:24 PM
RE: 48-460 squeal - by Jamie - 03-22-2014, 06:01 PM
RE: 48-460 squeal - by morzh - 03-22-2014, 06:27 PM
RE: 48-460 squeal - by Jamie - 03-22-2014, 09:06 PM
RE: 48-460 squeal - by morzh - 03-22-2014, 09:24 PM
There are currently 9794 online users. [Complete List]
» 2 Member(s) | 9792 Guest(s)
