Grill time! Making a replacement grill mold NEW PICS
funny you should post. I was going to update it this week. I am in the process of trying to make the grills but the mix of brown and black is not working out. I may have to make plain brown grills. The white and tan ones are easy but I don't have any produced and pictured. just a few failed tries.
I should have them being made within the next 30 days when I get a free minute, lol
RE: Grill time! - by TimC - 02-27-2014, 09:55 PM
RE: Grill time! - by morzh - 02-27-2014, 10:49 PM
RE: Grill time! - by OldRestorer - 02-28-2014, 10:04 AM
RE: Grill time! Making a replacement grill mold at home - by OldRestorer - 03-23-2014, 01:18 PM
Users browsing this thread: 15 Guest(s)
