Philco model 20 power transformer taps
Never mind,I figured it out-the wire is the CT for the 27's and the 24a's,it goes to the HVCT.
Phil
RE: Philco model 20 power transformer taps - by philco phan - 03-23-2014, 01:50 PM
There are currently 10507 online users. [Complete List]
» 2 Member(s) | 10505 Guest(s)
